another caster problem (1 Viewer)
Ft Worth. TX
Hello all... I am working on my brothers 97 fzj80 collectors edition and here is my problem.
I put the ome j lift and i am about 6 degrees off caster. the bushings that came with the lift as i understand it will not move the caster enough, so i bought the slee caster plates. the plates will probably move the caster to much so here is my question. if after i install the plates and the caster is too far corrected, can i install the bushings up side down to put it back close? or will it move too much back? any advise will greatly be apprieciated. oh and by the way, i do work in a shop with an alignment machine so i can check everything as i go.:p
thanks all!!!
thanks... i guess I'll give it a try and measure again.:bounce:
I just got the caster plates in and everything worked out great. got a perfect split at 2.4, up from -1.7! :cheers:
