Grounds are good, batteries are good, but when I went to start up after a month of being away, nothing. when I turn the key to the position just before ignition the fuel light below on the right does not come on, when I then proceed to turn but there is nothing at all. I know the system has power to a degree as my glow light on the left comes on at the push of the button, also head lights work. I am thinking it may be the starter relay? When I checked under the hood the Edic arm was extented in the fuel cut off position, took the arm off, forward lever will move by hand fore and aft, the lever near the firewall ontop of the EDIC unit seems stuck forward in the fuel cut off position, very stuck....would this be connected with the starter relay electics and as it is stuck in "cut off" disable the connection needed for ignition? Am on the breech of pulling the EDIC unit and having a look but thought some advice would be a better choice.
regards
J
J
