If this does not go in the hardcore section. The supermods can move it. I have a feeling that there are going to be a lot of post from Mace and Matt Mcinnes.
I plan on build a 2F + 3EFI engine. I have all the parts and have already ordered the gasket sets from Cruise Dan. The lower end gasket set for the 2F and the Valve Grind set for the 3FE.
Here is what I'm thinking about starting with.
2F that was a Man A Fre High Performance Engine. 3 of the lower rod bearings seized. Main bearings were are unharmed as well as the block but it will require a different 2F crankshaft.
Here is the 2F and the pistons compared to normal 2F pistons.
