Aluminum sliders?
Discussion in '80-Series Tech' started by RedmondCruiser, Jul 20, 2005.
  1. RedmondCruiser
    RedmondCruiser
    77
    Media:
    1
    5
    Apr 20, 2005
    WA
    Is there a reason why you don’t see aluminum armor? Is it too brittle? Is it too expensive? It would be nice to get the protection but also keep total rig weight down.
  2. Walking Eagle
    Walking Eagle
    3,228
    34
    Sep 6, 2003
    Tulsa, OK
    Aluminum is soft and rocks would get big grooves gouged out of it. It'd save some weight on sliders, but you'd have to put a sacrificial strip on the underside. Also welding aluminum is much more dificult, and most home fab guys just aren't set up for it.
  3. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    I make full use of my sliders. Mine are Slee's -- made of steel. I have dents in them from heavy use. I wouldn't want to know what they'd look like if they were made of aluminum. Wouldn't they be expensive to produce if you wanted similar strength as steel?
  4. chip7238
    chip7238
    120
    Mar 24, 2005
    Knoxville, TN
    Aluminum is pretty soft - for a slider, it would take a much thicker wall than steel to support the weight of the vehicle. I'm not even sure it would be possible to make aluminum sliders that work, but if it were, the additional Al needed for strength would outweigh the thinner steel by a long shot. Plus, there are economic considerations...additional Al = more money, etc.
  5. chip7238
    chip7238
    120
    Mar 24, 2005
    Knoxville, TN
    Doug, ya beat me to the punch...
  6. lx450landcruiser
    lx450landcruiser Moderator
    2,781
    10
    Sep 22, 2003
    Uganda
    i wanna see some one make stainless ones that would be sweeet and super bling
  7. Brentbba
    Brentbba Former Golfer SILVER Star
    10,303
    1,206
    Mar 27, 2003
    OC, CA
    Hmmm.....Doug, ok that's from getting in and out of the truck, but how are they on trails. hehehe :flipoff2:
  8. NorCalDoug
    6,294
    120
    Oct 27, 2003
    More attractive than yours :D
  9. Brentbba
    10,303
    1,206
    Mar 27, 2003
    OC, CA
    At this point, I'd agree. :D Yours show some lovin' mine don't......yet! :D
  10. landtank
    landtank SILVER Star
    19,455
    1,833
    Mar 27, 2003
    Groveland MA
    Aluminum sliders, that's a good one. You would probably be better off taping bananna peels to the rockers.
  11. leonard_nemoy
    leonard_nemoy
    523
    880
    Jan 19, 2005
    South west utah
    I was planning on making my roofrack out of aluminum but it would of been about 800 dollars instead of 150 so I just used steel.
  12. Junk
    Junk
    6,177
    31
    Dec 13, 2002
    buggerville nj
    The whole idea is to make sliders as sturdy as possible - beefy and can support the whole truck being dragged over rocks on them.
  13. speyrod
    speyrod
    576
    19
    Jan 1, 2005
    West of Seattle, not West Seattle
    Aluminium doesn't slide well over rock it has a tendancy to stick, at least it does in drift boats.
  14. elum
    elum
    353
    Apr 4, 2005
    Inland Empire
    aluminum is purty soft.. now titanium.. that's hard.. maybe a tad brittle in comparison to steel.. and more expensive for sure.. but weigh lighter.. heh heh
  15. Eskimo
    Eskimo SILVER Star
    1,358
    Sep 6, 2002
    Danville, PA
    There are some grades of Aluminum in the 70xx series that slide alot better than say, 6061 t-6, but it's still softer than steel.. and over time, it does become brittle.
    A friend has a 70xx skid on his buggy, and though it's lighter than mine, mine will slide over rocks better. (his is 3/8" alum, mine is 3/16" steel)
  16. cruiser97eric
    cruiser97eric
    18
    Media:
    2
    Albums:
    1
    Oct 1, 2007
    NW Las Vegas
    I know the arguments for steel sliders are strong, but I am also thinking about aluminum sliders in order to save weight.
    To my knowledge, the 6061-T6 aluminum has about the same tensile strength as the A36 mild steel many people use for home projects, but it is only 1/3 the weight. So even if I used 1/2" thick aluminum the weight would be lower than if I use 3/16" thick steel. I also like the fact that I won't have to paint or powder coat the finished project.
    What I am thinking about is using rectangular tubing with 1/4" thick wall, and possibly bolting on a 1/4" or 1/2" thick aluminum plate on the bottom side that can be turned over or replaced altogether as it gets chewed up by rocks.
    I am also considering the possibility of using extra slippery plastic on the bottom, such as UHMW PE or nylon, instead of or in addition to the aluminum plate. Has anybody heard of doing such a thing on sliders before?
    I am not concerned about cost because I have been collecting cheap surplus aluminum from local junkyards for years and I already have all the material I would need. I also have large surplus pieces of thick UHMW PE and nylon that I could use to cover the bottom.
    Welding the aluminum isn't a problem (I have TIG equipment), but I would try to use bolts whenever possible because I know welding weakens the T6 aluminum in the heat affected zones. Using bolts also makes it easier to replace damaged parts and to modify the design in the future. Any bolts would be stainless steel to minimize galvanic corrosion. The combination of aluminum and stainless works well on antennas so I hope it would give good results on sliders exposed to the elements too.
  17. Sc0-
    Sc0-
    1,245
    Media:
    2
    Albums:
    1
    49
    Jun 8, 2007
    Houston
    Aluminum, stainless, and steel.... For some reason that doesn't sound right. With all the effort to use Aluminum for sliders how light would the end product be and how long will it last? Someone here had a pic of some MetalTech sliders which has a good sized bend in the top tube, even Slee's slider tubes can take a bend so strength is paramount in a slider design... (Depengine on aluminum grade and heat treating if you are inclined is that some will bend while others will SNAP.)
    Would think the teflon strips would be meaningless unless you want to climb VERY slick and smooth obstacles otherwise they would just gouge and scrape off.. Would be better to use a stainless skin over the slider but then why all the effort to use aluminum. I would stick with Steel and FWIW would look to save weight by fabbing aluminum body panels, brackets, housings, Ti exhaust/intake.
  18. fjfar80
    fjfar80 GOLD Star
    1,273
    Media:
    3
    Albums:
    1
    37
    Jun 26, 2006
    NOVA
    Sounds interesting...I know a lot of buggy's have used "plastic" for full-body skid plates in Baja style events, etc. but, I am not sure how it would work when in contact with large rocks...interesting question though...I don't think it is just a matter of being "slick" I think you have to consider the friction factor with rock's sometimes having less than perfectly smooth surfaces and the fact that the LC weighs a few pounds more than a racing buggy...I am sure some of the more "physics" oriented members of the board can comment on the friction factor and applicability of plastic on sliders...
  19. C6H12O6
    C6H12O6 SILVER Star
    1,677
    Media:
    15
    Albums:
    1
    813
    Dec 23, 2004
    Beaverton, Oregon
    Use steel tubing and fill them with helium to offset the weight.
  20. Firedog
    Firedog
    469
    Media:
    3
    Albums:
    1
    3
    Jul 1, 2007
    Southwest Virginia
    Now that right there is FUNNY:D
