Alternator wirings please help
Hope someone would help me on this.
The car is a LC70 BJ71 with a 24 volt 13B-T engine, it has an original 40 amp alternator with external voltage regulator.
I converted it to a 70 ampere 24 volt alternator with internal voltage regulator already.
This new alternator has 4 wires
1. B- this should be the battery post with knot
2. IG - line to ignition switch
3. S- sensor charging ( dont know where it should be connected)
4. L- line to charging lamp
The old alternator external voltage regulator has 6-wires.
Please teach me how to connect these 4-wires of the new alternator to the line of the old external voltage regulator line, because the line of the old alternator came from this 6-wires plug of EVR.
i have installed the alternator already and its working properly.
i connect the Alternator output line directly to the battery positive terminal instead of connecting it to starter solenoid. I noticed that the battery positive terminal goes to the starter.
Is this connection ok?
