Alternator Upgrade and fusing
I made no real progress tonight, as the alternator has a threaded sleeve where the stock one does not. I was threading the length of the original bolt when I broke the die in half.
Regarding fuses: when wiring up the stock 120A alternator on my TDI I installed MIDI fuses in place of all the original fusible links in the Toyota harness, and also in place of the VW strip fuse for the alternator circuit. The VW uses a 150A fuse for the charging circuit, so that’s the rating I used for a MIDI fuse. To replace the fusible links I looked up the standard ampacity of the various main vehicle harness wires and used the nearest rated MIDI fuse. MIDI fuses are designed to be slow acting, able to handle significant inrush loads from things like window motors so they don’t blow when you decide to roll up all the windows while the headlights are on, for example. They are supposed to blow during a full short event to protect the vehicle harness from melting down and possibly catching fire.
I prefer to keep fusible links when they are used by the OEM. I put them in a terminal strip which makes them easy to replace, even in the field. I make a couple extra of each size and screw them to the spare terminals on the strip.
