Battery gauge jumps up and down when at stop light. Also does it when I hit the window switch. Is this normal? Loose wire? Alternator on way to grave yard? See videos.
Note: This feature currently requires accessing the site using the built-in Safari browser.
You have some funky electrical symptoms - which can be related to a failing or failed fusable link. Your fusable link looks like it's been cooked, so my suggestion is to test the fusable link to see if it's functional. The test device you need is an electrical multi-meter - available for less than $20 at any auto parts store. It has many different tests you can do, in the case of your fusable you want to test for continuity - ie to see if current is flowing through the fusable link or if it's burned out. A fusable link is a slow to fail fuse. It will take higher current longer. The test is easy to do. If you have no continuity, then you know your fusable is fried and that's the source of the problems.What do you mean "continuity"?
Continuity test.What do you mean "continuity"?
Doug, OP said his dash gauge is jumping, so continuity may be intermittent - it maybe different in motion than static if the FL connector is borked. Good to hook up the meter's leads and give the harness a wiggle....in the case of your fusable you want to test for continuity - ie to see if current is flowing through the fusable link or if it's burned out.
Bear in mind said:Yes, and I'm a fan of eliminating variables when possible. Everybody needs multi-meter, and maybe the fusables are fine, maybe they're the source of the problem, but they're easy to test.
Click here. As Lambcrusher said, think of a a fusible link kind of like a fuse. Same basic idea.I have the multi-meter but have never used it. Where do I put the leads to test continuity and FL's?
Mine is a 1989. Same set up for a 1989?
Could you build something for me and I'll buy it from you? Wiring is not my strong suit. Otherwise, what do you think about something like this...
Look at this on eBay:
Land Cruiser Fj 62 Fusible Link
