Factory alternator just failed last week. Driving home battery light illuminated voltage dropped from 14.4v to 13.2 volts when I pulled in the driveway. Checked it out the next day turned on the truck voltage was showing 13.8 when cold and hovered just above 13v when warmed up.
I ordered a denso reman, installed it Friday evening. Fired up voltage was back to 14.6v problem solved or so I thought, as it warmed up it would drop to 14.2v still great. While on a 1 hour trip I noticed the voltage went down to 13.5v battery light illuminated then a moment later my scan gauge is reading 16.9 volts! I pulled over stopped before it caused any damage, waited 10 minutes fired it back up and it's showing 14.3v. I proceeded with the drive and it went back to 13.5v with the battery light illuminated.
Turned the car on today and its back to normal again but if I drive for a bit it drops to 13.5v then periodically will jump to 16.9v. Did I get a dud?
I checked the wiring and alt s fuse. Put a multi meter on the alt a pin from the alternator and moved the wiring harness around expecting a possible short (voltage would drop or show 0v) but no dice. Any ideas are welcome.
