reddingcruiser
Practicing for retirement
I'm stumped. Everything was running fine, then gremlins attacked.
The 5.7 TBI won't run with alternator hooked up. Two wire alternator, if both are hooked up it will not start. Unhook either and it starts and runs fine (but won't charge, obviously).
It seem power spikes are shutting down the ECM, but I can't figure where it's coming from.
I'm taking the battery out this morning and taking it to NAPA to test.
I hate automotive electrical systems!
- New alternator has same condition.
- Have a spare ECM, same condition with either
- Battery grounded to engine, ECM grounded to engine, engine grounded to frame in two locations
- Checked solenoid
- Check engine light stays on with key on when running but no codes other than Code 12 (no faults)
- No arching when connecting/disconnecting battery, so assuming no shorts (at least external to battery)
- ECM and harness can be isolated from OEM harness by pulling fuses, engine ignition and starting circuits can operate separate with their own fuse panel. No difference either way.
