I've been chasing a low-voltage gremlim and while at NAPA last weekend, I had them test the battery to strike that from the equation. They said the battery is more than fine...1000CCA. But when I started up and they tested with "everthing on" they said..."Aaaah, you Alt is barely charging".
How much faith should I put in that test? the meter was hooked up only to the Batt.
Also, I had the Alt. amperage tested about a year ago and it was pushing 70A...could it be the VR?
just grasping at straws over here...any advice is appreciated.
Thanks.
Thanks.
