Alternate way to fill t case
Temecula
T case is severely Stripped. Tried almost everything and will try using a nut welded to the bolt next. But in the mean while, I need to drain and refill.
I was told to use the breather tube... but am I able to use the speed sensor that is right next to the fill plug?
The head of the 22mm hex is stripped? Or the threads are stripped?
try multi grips, it shouldnt be excessively tight
Fried that as well. And it it absolutely is!! It's pretty bad!!! Of welding a bolt doesn't work then I'm just gonna take the rear cover off and drill it out. Can't fit a drill in there with the gas tank getting in the way
