Update: This thread was initially started as a cry for help. Since the help came quickly and the problem became an opportunity, the thread has transitioned into a mini build thread documenting what it took to add an OEM e-locker to my 2001 4Runner. Enjoy.
I was planning on wrapping up my e-locker conversion this weekend. The wiring needed for the harness has been ordered and will be here Saturday. The rear locked axle has been cleaned and installed under the truck. The 4.10 front diff came out to make way for the 4.30. I transfered the ADD tube and mounts to the 4.30 diff. All was well until...
I noticed that the companion flange on the 4.30 diff is bent. It is spinning true around the pinion shaft. But one side of the flange that meets up with the driveshaft is bent in toward the diff ever so slightly. (See picture.)
Messing with the backlash and preload somewhat scare me. I don't think I have the proper tools or skill sets (or confidence) to reset them if needed.
I now have 2 spare diffs with perfectly straight companion flanges. I need some assistance or advice with this situation.
Do I just do my best to beat the bent flange straight?
Do I just install the diff and torque the front driveshaft to spec and hope for the best & no driveline vibration?
Do I just take the two diffs to someone and have them swap out the flanges?
Or, is the flange swap something that I really could tackle considering everything else I've already accomplished?
