- Thread starter
- #1
I installed the OME lift on my Cruiser, thanks to Kurt at Cruiser Outfitters. Along with my soft top from Trollhole
I took it for an alignment today. They did get the Toe right on the mark. I was looking for the other measurements to see if I should add Shims
I'll drive it a bit and see how it feels. This likely isn't big enough a delta to be an issue. Next time I am in there I might add a shim just to bring it into spec to see if it makes any difference. Its the engineer in me
Looking like these 1.5 deg shims for the left side to bring it to the top side of the spec and these 2.0 deg shims for the right side
would I need to do something about the center pin with this style? I like this style so I can loosen and insert rather than lowering the spring off the center perch
Here are my alignment results
