alcan springs with orbit eyes in los angeles
Redondo Beach
SOLD.
Have 1 set of spring over ONLY alcan springs with orbit eyes intalled
http://www.alcanspring.com
also
Spring perches
ubolt plates
Ubolts
Land Cruiser 3" Rear Axle Simple Swap Kit [LCRswap] - $120.00
2 sets of shackles (different mounting distances)
mounting hardware (9/16 greasable bolts with crimp nuts)
Located in Los Angeles
asking $400 for everything
http://www.alcanspring.com/
measurements:
48" eye to eye
24" to center pin
2.75 wide
Originally I installed the springs on my FJ40 project but the springs never made it out of the garage (never usded) before I changed directions and went with coilovers. The springs are much longer then stock
I hate to part with them because they are SOOO flexy.
brand new a several months ago
plastic wrap from delivery
installed on a mock up axle
This is a great price for a kit like this.
One thing. In order to reach the maximum potential target audience, and the MINIMUM number of tire kickers, you might want to also give measurements from the center pin to the frame end of the spring so that peeps know whether their axle's gonna move forwards/backwards from it's stock location. It makes a difference for things like shock mounting and auxiliary tanks.
Good luck with your sale.:)
Mark A.
Good god. So the 48" eye to eye is the stock measurement for a 60, right? 2.75" wide is the 60 width, so I can assume that it fits in the spring hangers. What's the weight capacity set up for? The 40 or is it heavy duty, so it'll work in the 60 application?
So $400 gets me the springs and greasable bolts and shackles?
$400 and everything is yours. No need to keep the springs and accessories as they will just collect dust and rust.
I dont know what the stock FJ60 lengths are.
Some mods are required.
The orbit eyte mounting surface is wider then the stock hangers so you would have to modify your forward hangers.
The rear poly bushing can used with the shackles provided which are bent to accept a poly bushing at one end then steps out to accept the orbit eye. I cant remember what the OD mounting surface is for the orbit eye but I can get it for you if needed.
Thanks
Looks like $400 will get you everything you see.
MrQtip is great to do business with.
DAMN I'm late to the party as usual. So what am i 3rd in line then?
