1973Guppie
Supporting Vendor
- Joined
- Jan 31, 2003
- Threads
- 952
- Messages
- 10,218
- Location
- "the whale's vagina", CA
- Website
- www.noahsarkstlc.com
96 fzj80 supercharged engine, already done the HG and rebuilt the top end. Truck runs great.
I have an air to air intercooler sitting on the shelf as well as the 2.8 pulley boys smaller pulley. I don't plan to change the tune on the truck whatsoever (not sure if that is even possible anyhow).
I am wondering if I should do BOTH the water to methanol injection with the air to air intercooler OR stick to one or the other? Is having BOTH overkill for not running a huge amount of boost? I am considering the MAF kit from snow performance. I do live in southern california so intake temps are a consideration. I don't have any high temp issues so far. Is a dual setup like this really only for guys running much higher psi boost?
I am also somewhat on the fence about installing the air to air intercooler as it is alot of work, ie: cutting the hood, etc. Plus all this stuff will have to come off in CA when I go to smog the truck, which is a PIA. The snow performance unit would be an easy thing to pull quickly before smog. Plus, from what I read the air to air intercooler actually drops the boost a few psi. I am thinking if I leave the A to A intercooler off and use the smaller pulley with the methanol injection I would end up with more power in the end?
not considering any other variations on the above, ie: turbos, water intercoolers, etc.
I am new to the whole supercharging, methanol, boost world so please bear with me. I appreciate any advice on what you think the best solution would be?
thanks,
Noah
thanks,
Noah
