On a 88 62, is the air pump the same thing as a smog pump on the 60's? Right above the alternator on the right side of the engine as you look into the engine.
Mine has a metallic ring while motor is running above 1000 rpms, kinda metal on metal bearing type noise. Looking to replace it but not really sure what it is called. FSM calls it the air pump but on mud everything is smog pump this and that...
Thanks
Thanks
