air-down question
Discussion in '60-Series Wagons' started by Jan-78FJ40, Feb 23, 2007.
  1. Jan-78FJ40
    Jan-78FJ40
    3,796
    476
    Sep 6, 2002
    Hi all,
    how far do you air down your 60s when going over bad washboard for a long ride? I am taking off to Baja in 10 days, and will be on looong stretches of really bad road. wondering where I'll set my staun-deflators.
    On alphalt I run at 45psi...
    thanks!
    J
  2. brokenparts
    brokenparts
    4,041
    86
    Apr 4, 2006
    Hillsboro, OR
    depending on the speed and turns, I wouldnt go much lower than 12ish without beadlocks.
  3. chicago
    chicago
    9,620
    Media:
    21
    Albums:
    1
    35
    Jan 18, 2006
    Reno, Nevada
    X2
    Doing the washboard down in Sailine valley, I ran it (relatively) comfortable at 19-20 PSI!
    My rig was loaded down like a motha too!
    Have fun and post pics!
    Chicago
  4. kevinmrowland
    kevinmrowland Forum Lifer
    2,278
    Media:
    16
    Albums:
    1
    29
    Sep 2, 2005
    Eugene, OR
    Whatever works.
    For me:
    6,120lb 60 series, speeds up to 45mph, 20psi (no pavement) slower driving, 15psi.
  5. mtb_rider
    mtb_rider
    881
    2
    Feb 17, 2007
    Wilsonville, OR
    I've heard you can run as low as 9 without locks, but that was on sand. On pavement, probably wouldn't go quite that low. I'd say something in the 15-20 range would probably be a nice ride, and safe.
  6. brownbear
    brownbear Mod in Hibernation Moderator
    6,751
    75
    Sep 6, 2004
    North West Ontario
    Jan, I would not go lower than 20-25 if your wanting to clip along. Even 30 would be safer.
    Maximum traction you can go down to 15 or lower what ever... But cruising on washboard I would not lower it too much.
    Low pressure tires create more heat by sidewall flexing and could blow out. Causing tire failure on the side wall.
  7. cruiser88
    cruiser88
    11,878
    Media:
    3
    Albums:
    1
    133
    Feb 21, 2006
    Winston Oregon
    if i were you i would not run any less than 20
  8. philos1
    philos1
    1,593
    Feb 8, 2005
    the valley, yeah that one
    I actually DO NOT air down for washboard-especially Mexican washboard... I've been to BAJA a number of times and have driven the vizcaino peninsula with some good frequency.... just try to keep up a steady speed and float over the tops. OME shocks help the most, the low pressure nitrogen seems to love this type of terrain. I usually try and keep it around 35 MPH when I can see ahead, slower when I can't. Dry lake beds, well.... near freeway speeds if vision is good.
    just my experience and OP. HTH :)
  9. CruisinFJ60
    CruisinFJ60
    6,158
    Media:
    219
    Albums:
    8
    35
    Oct 19, 2006
    Ft. Worthless, TEXAS!
    i run my 35x12.50x15's at 28-30psi on the street everyday...
    good ride and tires wear even.
  10. lovetoski
    lovetoski SILVER Star
    4,534
    203
    Jul 13, 2003
    To start off...I fully admit that there's a lot I don't know. However I can speak to my own experience. I've driven a local long gravel road (middle fork of the snoqualmie river) a number of times, both at "freeway" pressure and aired down. I have 33X10.50's which have a max pressure of 50 psi. I run them at 35 psi for most driving. Higher when fully loaded for the highway portion. On this road, at 35 psi it beats the crap out of me and my passenger (my son). We've aired down to 20 psi, and it's a huge improvement. HUGE. We've aired down to 15 psi, and it's somewhat better than 20, but for gravel washboard roads, not so sure it matters.
    HTH.
  11. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    Ive put a good amount of miles on my tires at 12-15 psi at speeds of up to 55 (going straight) without issue. They are loud though, and you can hear them squeak sometimes when making sharp turns, it sounds cool.
  12. roscoFJ73
    roscoFJ73
    14,783
    Media:
    3
    Albums:
    1
    1,278
    Jul 22, 2003
    Perth Western Australia
    x2 I would only go below 20 for soft sand in long stretches. Stuck on a beach with a rising tide,as low as necessary to get moving;)
    On rough roads,25 -30psi soaks up what the suspension cant handle.
    I use the Staun deflaters and Im pretty happy with them.
    ARB have a new device that airs the tyres down one at a time quickly by unscrewing the valve without allowing it to fall out
    It has a gauge on it so you can see how much psi you have.
  13. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    I have the new arb tool, it is sweet. It keeps the valve stem nice and centered too so you dont have to worry about it going in crooked or anything.
  14. Sherpa 60
    Sherpa 60
    176
    Dec 19, 2006
    Lafayette, CA
    I agree with philos 1. In Baja on paved roads and fully loaded I keep 40-45psi in my BFGs. Driving dirt roads / washboards I drop the air a bit...say 25-30psi. Most of the graded roads are pretty solid and traction isn't a problem. The washboards...build up speed and float over them. It's the occasional rock that may cause the problem...so the 25-30psi. is a bit of a safety net.
