Air cleaner still wont clear hood! Help!
Florence, SC
OK - I finally got an oem aircleaner albeit I have to adapt it down to fit a 1bbl carb...
The problem is - It still wont allow the hood to close...
Is the spacer between the carb and intake necessary????? It has a red hose going to the oil filler tube....I'm not sure its purpose but If I could take off the spacer The air cleaner would clear.....Thanks for your help......
This is the air cleaner I'm trying to make work..
OK - I figured out the pcv valve but what am I missing with this setup that prevents the hood from closing without hitting the aircleaner? I've even tried the smallest air cleaner possible from the local auto parts store but it still hits...
I even thought the guys that sat the tub back on the chassis might have missed the pads but the new ones are there....
I need clean air...
Well, the red hose goes to the PCV and has to have amifold vacuum, but you can route it to the manifold instead of the spacer. But, the spacer is also an insulator to keep heat away from the carb and is there in some form or another on all stock setups AFAIK.
I think the 1BBL carbs had the same style aircleaner, dunno why it would not fit. :confused:
The originals were oil bath, maybe that is what you need?
Ed
I put on this small filter...took the chrome "top" off...backed the screw that holds the top back so It would be below the actual filter....I put some oil on top of the filter so it would mark the hood it it touched it.....
It was close but I couldnt even close the hood....From the top of the 1bbl Aisan to the top of this filter in pic measures exactly 3 inches....To clear the mounting bolts for the windshield rest and windshield hold downs I'd need the total aircleaner assy to be no taller than 2 1/4 to 2 1/2 inches....
I've got to be missing something right???
Howdy! We used to make air filter housings out of two pie pans. One with a hole to fit over the carb, the other with a hole for the mounting bolt. Just go to the parts store and find a filter element that is short enough to clear your hood. John
Here are some pics of mine. Maybe this will shed some light
Let me know if there are any specific measurements you may need
I will look for my old single BBL air cleaner cover. Looking at your lics it looks as though that spacer is your issue. There is not a ton of wiggle room there
Well, that was easy.... I just found an old single BBL oil bath air cleaner assembly. Shoot me a PM and i can ship it out to ya......if you think you need it.
You can gain 1/2" or more by useing a carriage bolt with nut on top on the windshield bumpers.
Place a level on the top of your carburetor to mark it's height on the firewall and measure the vertical distance from the hood seal on the firewall down to the top edge of the carburetor. I bet somebody here will get that measurement from their rig with a 1barrel for you.
I would... but the engine is on a stand right now, and the carburetor is in a box.
I think he figured this out about 3 years ago.....:hhmm:
