O
oldgrey60
Guest
Do most of the P/S conversions out there require removal of stock air cleaner can and related hardware?
Note: This feature currently requires accessing the site using the built-in Safari browser.
65swb45 said:Since there is no year or make of vehicle specified, I'll hazard a guess that it's NOT the FJ60 in your avitar, which would have come stock with PS. That said, if you're in a non-smog state with a pre-PS motor, the easiest setup is to run the pump on the lower left [driver's] side of the engine, with the alternator up top on the passenger side. This configuration should NOT interefere with either type of air cleaner .
handcannon said:Mark--currently have manual sag box but considering future upgrade to power. Are the brackets available for these locations for a 71 FJ40 or do they need to be fabbed? Thanks for any info!
