Would you guys do anything with these values?
Yes, assuming neutral heights are all correct (or adjusted how you want them), I'd turn the torsion bars until Front is around 6.7. I'd consider adding rear King springs or 30mm spacers. The springs would be good if you plan to add any weight (rear bumper, cargo system like the SS1, or regular towing). The spacers would be good for continued use loaded up as it was for this screenshot.
dchilds, I'd be tempted to call your front height fine and move on. You can adjust the sensors a bit to raise it slightly, but then you'll have to tighten the torsion bars again, and I'm not sure that's worth the effort. Buy some new OE springs or spacers and call it a day.
100% agreed. @dchildsI would not sweat 1/4" height delta on the front fender to hub center distance. IMHO that "spec" needs plus/minus 1/4" tolerance anyways.
I took a few more pressure readings and my average came down a hair. I put one full turn on each TB and rechecked. I came up with a value of 6.6. I think I'm on target. As far as the rear goes, this is my daily driver and I don't carry much weight around for long periods of time. On occasion, I'll have it loaded up for a hunting trip etc. but no constant load. I assume I just get new OEM springs, correct?
My front height at neutral is sitting just under 19.5. I'm reading the target is 19.75". My height sensors are 0" +/-.1". What do I do from here?
Not a ‘pro’ but
