8 months ago truck burst the drivers rear feed pipe from control valve to sphere. I ended up replacing all the feed pipes from each sphere to control valve and replaced fluid with proper toyota stuff. Truck eventually levelled up with some playing about with diagnostic active tests of actuating front and rear levelling solenoids. Drove it for 5 miles and it suddenly dropped both drivers front and rear corners. Put it back on ramp and the feed pipe from drivers rear sphere to shock was weeping so I assumed loss in pressure caused the drop. Toyota wanted £400 plus vodka and tonic for pipe so managed to source from UAE for £130 plus shipping Pipe arrived after a long wait with shipping restrictions, got it fitted and now I have a new issue. As soon as truck levels up on N height it holds pressure for 1-2 secs then drops on drivers side. Checked height sensors all seem fine. Have tried bleeding/driving and all sorts but I have a 10cm difference between front heights and led is holding at N. I’m having a wild guess but it seems to me like the control valve may be faulty it is showing no DTC codes. Or is possible I have mixed up the control valve feed pipes when replacing as the truck is raising left side/right side not front/rear? |
