Well I did an AHC fluid change this weekend. Before I even started, I went to put the suspension in Low mode, and siphoned out the fluid out of the reservoir. When I laid down to start draining the fluid out of the bleed fittings, I noticed a few drops of fluid hanging from the globes. Seems like I saw them on all of the globes, but definitely on both the front and rear driver side.
I went on with the fluid change anyway. I only did the 4 bleed fittings, didn't find the fifth one. Filled up with 2.5 liters of fluid and tested it. It seems to work now, but I haven't put it in low mode yet, which is when the leak became apparent before the fluid change. Does this mean anything - the beginning of the end of the system?
