Just installed an Alpine CDA-9813 and its pretty sweet. My stock CD died and I wanted to play MP3s. I'm using the internal amp and I wired it up using Metra cables so it was all plug and play. I ran 10 guage power and ground from the battery though as the factory power wire in the harness is too small. I also set up 2 power blocks, 1 switched and the other constant. I hooked up some extra lighter sockets and a converter so I can plug in my phone, computer or any of the kids' stuff. Next step will be some new speakers after I recover. Currently, all the speakers work and it doesn't sound bad but I know when I replace the speakers it will be like "WOW!!"
Anyways, the Alpine took me 3 days to install. Why you ask? It kept heating up and would shut off after a song or 2 with the tuner on. Disks would play OK. I even took the original unit back and exchanged it but the second acted the same. Went out to the stereo installer boards and nobody helped. I even found a post from a year ago from a guy with the same problem in a '94 like mine.
Then I remembered way back in my beer-soaked brain a post I had read here and somebody said to "not connect the power antenna lead." I remembered wondering "why would there be a power antenna lead when we don't have automatic power antennas?" So, I took that lead wire out of the harness and all is well! Heat sink never got over about 85 degrees after 10 minutes so I bolted it in and buttoned up the dash. Love that fan that Toyota put in there for us!
Anybody know why this happens or am I just crazy?
Randy
Randy
