I recently installed a Slee bumper on my 06 LX470. It's a great bumper but I knew that blocking the back-up camera was going to be an issue for me. I ordered Slee's bracket which mounts the camera in the center of the tire carrier, but I decided that I didn't want to block my camera when running a Trasharoo.
While I'm not a fabricator, I figured there are plenty of places to mount a camera on the bumper and that a good shop could figure out a solution that would work for me. So I turned to Baertrax. I hadn't been there before, but they have a great reputation.
They ended up putting together a really solid solution. I think it ended up being a bit more work than Josh had initially estimated, but they really do quality work.
I wasn't there for the entire install so I don't have a bunch of pics, but basically they pulled the wiring harness completely out of the upper part of the rear hatch (vs cutting the ends off and leaving the rest of the harness like I've seen elsewhere), and then rerouted it to come out and run alongside the license plate wiring on the swing arm.
I'm sure you could get it done cheaper, but I don't think you could get it done better.
