Aftermarket AUX Fuel Tank
cruiserjunktion
Cruiserjunktion@gmail.com
Supporting Vendor
GOLD Star
North Florida
Hello,
The PO of my 74 installed some interesting aftermarket parts. These include but are not limited to: Wooden tailgate & running boards, block heater, aux fuel tank etc. Tossed the wood parts but considering keeping the tank.
The tank has four holes that go thru it. It is mounted with long (18") bolts. The PO drilled holes in the bed to attach it to the truck.
I have seen other tanks that mount between the frame similar to mine. Those used straps for attaching to the vehicle instead of bolts.
Does ne1 have a similar tank?
Pros Cons?
Capacity?
Cleaning?
Plumbing?
Thanks
Mel
NE GA
I got one of the strap on ones,, wait that sounds bad,, uh,,
anyway, I took it to a radiator shop they boiled it out and lined it 50$, the lining is supposed to keep it from rusting out
pros
now I can go 300+ miles on a fill up (30 or so gallons)
cons
20 gallon or so extra capacity makes the price to fill up shock your heart
if you wheeling you can crunch it
holds water and mud to help rust out cruiser faster
makes working on the diff harder
where are you at? GA FLA?
Morse_FJ40
Anchorage, AK
I have a 22 aux tank from conferr, and I love it. I can haul 37 gallons. Mine attatches with a skid plate that bolts to the rear crossmember, and straps that hang on the tubular crossmember.
later
Ryan
dieseldog
She idles just fine . . .
GOLD Star
Houston & BFE
I had one of the Manafre units in my 60 years ago (long range tank not an aux.). It had the tubes through the tank and bolted through the floor. It was a simple setup and it gave me no troubles. I'd have to say that I like the strap design better though.
SoCal
We have pretty much switched all of our tanks to the strap design. Its easier too install, and just better built all around. The con-ferr tank is not bad by any means, just a little out dated. The mounting design and skid plate were its weakness.
Steve
Sunspot AZ
I have the Northwest Metal Products tank. It holds 22.5 gallons. A nice addition to the cruiser. Factory 15 gallons is far from adaquate.
Dallas, Texas
I wanted to add an aux gas tank to my first cruiser but never got to it before being totaled by drunk driver. I'd like to add one to my 76 because the 15 gal. really doesn't cut it. I have never seen one on a cruiser. Does anyone have pics of theirs?
