Since finding triple locked 80 series Cruisers is getting more and more difficult, what are the best aftermarket lockers to install on an 80?
The kind that fit the truck and your budget.Since finding triple locked 80 series Cruisers is getting more and more difficult, what are the best aftermarket lockers to install on an 80?
Thanks for the insight. One last question, I am looking at purchasing an 80 (going to look at it Saturday) and the seller says that the center differential is engaged but he cannot get it to release. Any ideas what the problem might be? Simple to complex?
Vehicle is a 94. Thanks for your insight!Center Diff would be the Transfer-case. The differential there is 'locked' via an actuator. IF it is truly stuck....the reason for it could be quite simple or might take a little 'doing'. But certainly not insurmountable. What year model is the vehicle?
Some Tcases had/have a Viscous Coupler that can 'seize'. Hopefully the seller knows the difference. Even if that were the case, it can be removed with no ill effects to performance.
Where in Alaska? With a '94, I believe that the center diff lock only engages when in low range unless it's been modified, so perhaps the beast is stuck in low range.
Share a photo or two if you can, and good luck.
I agree. New after market are the way to go.I have an 80 with arbs they work great. I had to fix a major leak with in the rear when I first purchased it but since then they’ve been great. My girlfriend has an lx450 and her oem lockers also work great.
I also acquired an oem locked 80, those don’t work great. And I’m pulling my hair out trying to get them and the center diff lock to work.
I’ve come to realize that seeking out a factory locked 80 is not worth it. And the increase in serviceability, strength, and ease of use is well worth the cost of aftermarket lockers
