after 3+ years: SwayAWay torsion bars
Discussion in '100-Series Cruisers' started by drexx, Jul 27, 2005.
  1. drexx
    drexx
    540
    8
    Sep 8, 2003
    28Jul2005 (UTC +8)
    After more than three years, or 60,000+ miles, I can say that I'm fairly happy with my Sway-A-Way torsion bars. With my ARB Sahara bar (just a coupla months after the torsion bars), dual battery setup, and now TRD supercharger to load the front end, they've been sagging every now and then so I had to crank up the torsion bars to maintain the lift. So just today I reset the whole thing by removing and re-installing them so that my IFS up-stroke could be better. I guess this longevity factor is an obvious advantage of torsion bars vs. coil springs.
    The torsion bars had outlasted a regular set of OME shocks, so now it's running with nice OME LTR for more than a year now. It has also been mated to stiff OME coil springs for the rear --which just dropped down a bit 'coz of the Long Ranger aux fuel tank and Kaymar rear bumper and the often-used 3rd row seats-- but those coils ain't sagging yet definitely.
    Would I buy them again? Maybe not, as OME & TJM torsion bars are much cheaper. But anything is better than soft and wallowy Toyota suspension!
  2. calamaridog
    calamaridog
    2,607
    21
    Jun 6, 2003
    Cuyamaca, CA and Las Vegas, NV
    They cost more than double the cost of a set of OME:eek:
  3. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,821
    6,583
    Jan 9, 2003
    Utah
    What lift range did you acheive with the SAW's, near identical to the OME/TJM setup? Or was it maintainable at higher heights?
  4. calamaridog
    calamaridog
    2,607
    21
    Jun 6, 2003
    The SAW torsion bars are 31mm vs. 30.? for the OME. Not worth the extra $$ in my estimation.
    You may be able to carry them at a decent price, that would be nice. The only people I could find who had them was MAF and they want over $600 for them.
  5. cruiseroutfit
    8,821
    6,583
    Jan 9, 2003
    Utah
    One of my partner companies (company I do a ton of work back & forth with ;)) is a SAW dealer... I will see what they can swing. Though, I have only moved a couple of the OME set-ups, I can't see the SAW parts moving either... :D
  6. calamaridog
    calamaridog
    2,607
    21
    Jun 6, 2003
    Kurt,
    Just curious but I've already got a set of OME in the garage. I just like to know what my options are;)
  7. spressomon
    spressomon glutton Moderator
    12,591
    Media:
    13
    Albums:
    1
    1,203
    Jan 9, 2005
    Northern Nevada
    I wonder, as the t-bar OD increases, if droop/drop also decreases. Or does travel remain a constant since, theorectically, less pre-load needs to be applied to a larger OD t-bar for a given lift height. Or, since there would be less pre-load/wrap on the larger OD t-bar is overall travel reduced since there would be less spring-inches of movement?
    Having said that I do understand there is a point, in lift height, where droop/drop is diminished. It would be worthwhile to plot this data...has anyone done this? Christo?
