Advice on 3speed transmission issues
NORWOOD,COLORADO
I have a new to me 1969 fj40, the po said he put a new clutch in but as I shift through the gears it works great. When down shifting it grinds going into gear. It is the orgnal 3 speed on the tree, I can double clutch it and it still grinds. Is it the syncros?
Any advice would be much appreciated.
QuackAxel
Corvallis, MT
Theres no syncro in first gear on the three speeds. So no matter what you do.... It's always gona grind going into first. Second and third should not grind.
If you dont like it swap it out for a 4 speed
NORWOOD,COLORADO
I would like to try to keep it original if i could. There has to be a fix.
erie pa
if its grinding in second and 3rd downshifts it may need rebuilt,1st gear requires lots of practice.also the 3 on the tree lincage may be sloppy after all these years.
GregRay
Old Member
Horse Country, NJ
The key to the 3 speed is that you NEVER downshift into first gear. Only use first when you are stopped.
If you can properly double clutch it won't grind going into ANY gear. Just a matter of getting the technique right.
stock '77 fj40 with 31x10.5's daily driver
NORWOOD,COLORADO
Yes, only using first gear when stopped. Its just that 3rd to second that is grinding.
If it goes into gear easily when you're stopped with the engine running then it's not the clutch. I usually double clutch going into 3rd on my 4speed because the synchro is worn.
Also if the synchro is in good condition and you try to put it in gear without using the clutch (matching the revs) you will feel some resistance of the synchro trying to speed up or slowdown the input shaft. You would have to push reasonably hard to get past this for it to grind. So basically start the engine. Try to put it into 2nd without the clutch. If it grinds easily without prior resistance I'd say itd be the synchro.... Which is most likely anyway because over the years 2nd would be the gear most often changed down too in turn wearing the synchros (3rd on a 4speed).
BB
San Ramon, CA
I'd check to be sure the linkage is properly adjusted and go from there. That was always the issue on my old Ford three speed.
San Tan Valley Arizona
If it were me I would find another 3 speed. Probably cheaper to replace than repair. Most people give away the 3 speeds
