Advice needed - single owner LX470 2002 with 220k miles for $8000 (2 Viewers)
Norcal
Link: Lexus LX 470 SUV (2002) for sale
Hello folks, I've been looking at LX470s for a while and I thought this one was already out of my grasp but it appears a few people have passed on it. The transmission was replaced in it, so that's a big question mark.
The seller is in the process of moving and are temporarily staying with the person who is responding to the text/phone calls, it sounds like the owners are older.
I'm going to have to drive a few hours to get it, so I was hoping someone could chime in before tomorrow morning if this seems alright, and what to look out for.
From the records it looks like it's been in the Bay Area all its life, and had regular oil changes, even if all of them are not documented. I surmise this because when the oil changes ARE documented, they are at 5k intervals.
Lexus service records:
SERVICE HISTORY
SERVICE HISTORY FOR:
VIN: JTJHT00W723519768
9550 MILES
DATE:
07/19/2007
REPAIR# 0085751
REPORTED BY: Lexus of Concord, LLC
SERVICE: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE
DESCRIPTION: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~95495 PERFORMED 5K SERVICE. FRONT BRAKES AT 10MM REAR BRAKES AT 10MM FRONT AND REAR TIRES AT 8/32 ANTENNA MAST IS BROKEN($225.00)
SERVICE: MISC
DESCRIPTION: MISC ~|~DROP 4 HRS MIKE E. ~|~ ~|~95495
89705 MILES
DATE:
03/08/2007
REPAIR# 0336925
REPORTED BY: Lexus of Pleasanton
SERVICE: ALIGNMENTS/TIRES
DESCRIPTION: ALIGNMENTS/TIRES ~|~CUSTOMER REPORTS THE LEFT REAR TIRE WENT FLAT. CUSTOMER CALLED ROADSIDE ASSISTANCE, THEY CAME OUT, BUT STATED THEY COULD NOT LOWER THE SPARE TIRE. SEEMED LIKE THERE IS A PROBLEM WITH THE LOWER DEVICE. PLEASE CHECK AND ADVISE. ~|~R/R TIRE HAD NAIL , NEEDED REPAIR 3 ~|~REPAIRED TIRE AND LOWERED SPARE TIRE WITH TOOL KIT, WORKS FINE
SERVICE: LOANER CAR
DESCRIPTION: LOANER CAR ~|~SUPPLY LOANER CAR DURING VEHICLE SERVICE PLEASE RETURN LOANER VEHICLE WITHIN 24 HOURS AFTER NOTIFICATION OF YOUR VEHICLE BEING READY OR A $75.00 PER DAY FEE MAY BE ADDED TO YOUR INVOICE. PLEASE RETURN THE LOANER CAR WITH THE SAME AMOUNT OF FUEL NOTE-THERE ~|~ ~|~SUPPLIED LOANER CAR DURING SERVICE VISIT
84504 MILES
DATE:
11/18/2006
REPAIR# 0071732
DESCRIPTION: CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 5,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~84503 COMPLETE 5K SERVICE FRONT BRAKES 5MM REAR BRAKES 2MM PAD REMAINING. ALL TIRES 9/32"" TREAD REMAINING AND SET PRESSUR E TO 33PSI.. RECOMMEND REAR BRAKE SERVICE TO BE PERFORMED
SERVICE: REAR BRAKE SERVICE
DESCRIPTION: REAR BRAKE SERVICE ~|~CUSTOMER REQUEST REAR BRAKE SERVICE TO BE PERFORMED ~|~ ~|~84503 MACHINED ROTORS AND INSTALLED NEW PADS. TEST DROVE FOR NORMAL OPERATION
78726 MILES
DATE:
07/12/2006
REPAIR# 0064049
SERVICE: LUBE OIL AND FILTER (LS400)
DESCRIPTION: LUBE OIL AND FILTER (LS400) ~|~LUBE OIL AND FILTER (LS400) ~|~ ~|~78726 PERFORMED OIL AND FILTER SERVICE
SERVICE: OPENED CUP HOLDER
DESCRIPTION: OPENED CUP HOLDER ~|~CUSTOMER STATES THE CENTER CUP HOLDER WIL STUCK ~|~ ~|~78726 CUP HOLDER STUCK CLOSED ADD STICKY STUFF IN IT ADDED DRY LUBE
74966 MILES
DATE:
05/02/2006
REPAIR# 0060013
SERVICE: CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE
DESCRIPTION: CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~CUSTOMER REQUEST PERFORM 75,000 MILE SERVICE AS PER PREMIUM SERVICE GUIDE ~|~ ~|~74965 75K SERVICE COMPLETED PER MENU.FRONT BRAKES 7MM REAR BRAKES 6MM PAD REMAINING.ALL TIRES 9/32"" TREAD REMAINING AND SET PRESSURE TO 34PSI.
70391 MILES
DATE:
01/30/2006
REPAIR# 0055013
SERVICE: PERFORMED 70K SERVICE
DESCRIPTION: PERFORMED 70K SERVICE ~|~PERFORM 70K SERVICE ~|~ ~|~PERFORM 70.000 MILE SERVICE FRONT BRAKES AT 8MM REAR BRAKES AT 8MM
67727 MILES
DATE:
12/02/2005
REPAIR# 0052025
SERVICE: TIRE REPAIR
DESCRIPTION: TIRE REPAIR ~|~GUEST STATES LEFT FRONT TIRE LOSING AIR. OK TO REPAIR TIRE IF POSSIBLE. OK REMOVE ALL WHEEL LOCKS AND SAVE. ~|~ ~|~67727 TIRE HAD NAIL REPAIRED TIRE . REMOVED LOCKING LUGS AND PUT IN CUPHOLDER TEMPORARILY UNTIL WHEEL LOCK KEY ORDERED BY CUSTOMER COMES IN.
65591 MILES
DATE:
10/29/2005
REPAIR# 0050477
SERVICE: 65K MILE SERVICE PER MENU LX470
DESCRIPTION: 65K MILE SERVICE PER MENU LX470 ~|~65K MILE SERVICE PER MENU LX470 ~|~ ~|~PERFORMED 65K MILE SERVICE PER MENU LX470
60480 MILES
DATE:
07/07/2005
REPAIR# 0044831
SERVICE: 5LB INSTALL DRL KIT MY03-05 LX470 (SSC)
DESCRIPTION: 5LB INSTALL DRL KIT MY03-05 LX470 (SSC) ~|~5LB LX470 DRL KIT ~|~PERFORMED 5LB CAMPAIGN PER SSC ~|~60480 CAMPAIGN 5LB IS COMPLETED
SERVICE: 60K MILE SERVICE PER MENU LX470
DESCRIPTION: 60K MILE SERVICE PER MENU LX470 ~|~60K MILE SERVICE PER MENU LX470 ~|~ ~|~60480 60K MILE SERVICEE IS COMPLETED BRAKES AT F=9MM R=9MM TIRES ARE BADLY WORN OUT ON THE RIGHT SIDE AND LEFT SIDE TIRES ARE BETTER. RECOMEND 4 TIRE
SERVICE: COMB: OPPOSITE SIDE
DESCRIPTION:
SERVICE: DRIVE SHAFT BOOT (ONE SIDE)
DESCRIPTION: DRIVE SHAFT BOOT (ONE SIDE) ~|~DURING SERVICE FOUND CV BOOTS LEAKING GREASE ON LEFT AND RIGHT SIDES ~|~CV BOOTS TORN ~|~60480 REPLACED BOTH AXLE BOOTS OP CODE 434651 T165 T212 1.4 AND .8 C
SERVICE: MISC
DESCRIPTION: MISC ~|~CUSTOMER STATES LETTERING ON REAR OF VEHICLE WAS INSTALLED WRONG AT BODYSHOP, TRY TO PUT ON CORRECTLY ~|~ ~|~60480 REMOVE EMBLEMS 4 AND 7 AND INSTALLED THE RIGHT WAY. CLEAN OLD GLUE AND ADD DOUBLE SIDE TAPE TO IT.
SERVICE: PERFORMED 4 WHEEL ALIGNMENT
DESCRIPTION: PERFORMED 4 WHEEL ALIGNMENT ~|~PERFORMED ALIGNMENT AFTER TIRE REPLACEMENT ~|~ ~|~60480 PERFORMED ALIGNMENT
SERVICE: REPLACED 4 TIRES
DESCRIPTION: REPLACED 4 TIRES ~|~DURING SERVICE FOUND TIRES WORN ON INNER EDGES ~|~ ~|~60480 REPLACED 4 TIRES
SERVICE: REPLACED FT STRUTS
DESCRIPTION: REPLACED FT STRUTS ~|~DURING SERVICE FOUND FRONT STRUTS LEAKING FLUID ~|~ ~|~60480 REPLACED FRONT STRUTS
37999 MILES
DATE:
06/07/2004
REPAIR# 0026065
SERVICE: 143
DESCRIPTION: 143 ~|~40,000 MILE SERVICE ~|~ ~|~PERFORMED SERVICE BRAKES FRONT 4MM REAR 4MM REMAINING TIRES FRONT 7/32 REAR 7/32 REMAINING RECOMMEND TO REPLACE FRONT AND REAR BRAKES FRONT $784.00, REAR 340.00.
32887 MILES
DATE:
03/19/2004
REPAIR# 0022300
SERVICE: NO PROBLEM FOUND, VEHICLE WORKING AS DESIGNED
DESCRIPTION: NO PROBLEM FOUND, VEHICLE WORKING AS DESIGNED ~|~CUSTOMER STATES HEARS HISSING NOISE WHEN TURNING LEFT AT END OF TURNING STEERING WHEEL INSPECT AND ADVISE ~|~ ~|~VEHICLE OPERATING AS DESIGNED NORMAL FUNCTION OF STEERING SYSTEM
SERVICE: PERFORMED 35K MILE SERVICE PER MENU
DESCRIPTION: PERFORMED 35K MILE SERVICE PER MENU ~|~35K MILE SERVICE PER MENU LX470 ~|~ ~|~PERFORMED 35K MILE SERVICE PER MENU LX470
27760 MILES
DATE:
12/11/2003
REPAIR# 0017567
SERVICE: 30000 MILE SERVICE
DESCRIPTION: 30000 MILE SERVICE ~|~30000 MILE SERVICE ~|~ ~|~PERFORMED SERVICE BRAKES FRONT 4MM REAR 4MM REMAINING TIRES FRONT 8/32 REAR 8/32 REMAINING
SERVICE: INSPECT CD PLAYER
DESCRIPTION: INSPECT CD PLAYER ~|~CUSTOMER STATES THAT THE CD PLAYER SKIPS WHEN PLAYING CD'S
SERVICE: REPAIR RATTLES
DESCRIPTION: REPAIR RATTLES ~|~CUSTOMER STATES THAT THERE IS A NOISE IN THE REAR OF THE CAR LIKE SOMETHING IS LOOSE, LIKE THE SPARE TIRE
22855 MILES
DATE:
09/10/2003
REPAIR# 0013199
SERVICE: 10,000 MILE SERVICE OIL & FILTER CHANGE
DESCRIPTION: 10,000 MILE SERVICE OIL & FILTER CHANGE ~|~PERFORM 22,500 SERVICE PER MENU ~|~ ~|~FRONT BRAKES AT 5MM REAR BRAKE AT 6MM
SERVICE: LUBED WINDOW TRACK
DESCRIPTION: LUBED WINDOW TRACK ~|~CUSTOMER STATES THE RIGHT REAR WINDOW MAKES A SQUEEK NOISE WHEN ROLLED DOWN ~|~X
16078 MILES
DATE:
05/29/2003
REPAIR# 0139002
SERVICE:
DESCRIPTION: 6MM FRONT BRAKE PAD REMAINING 7 MM REAR BRAKE PAD REMAINING NEW=10MM, REPLACE AT 2 MILLIMTRS 7 /32" FRONT TIRE TREAD DEPTH 7 /32" REAR TIRE TREAD DEPTH NEW=12/32", REPLACE AT 2-3/32" SERVICE MENU COMPLETED
SERVICE: 15000 MILE SERVICE (LX450) CHECK AND TOP FLUIDS & ROAD TEST CLEAN BATTERY CABLES
DESCRIPTION:
SERVICE: AIR CLEANER FILTER ELEMENT R&R
DESCRIPTION:
SERVICE: AUTOMATIC TRANSMISSION OIL LUB
DESCRIPTION:
SERVICE: DIFFERENTIAL OIL RPL
DESCRIPTION:
SERVICE: ENGINE OIL RPL
DESCRIPTION:
SERVICE: INSPECT BALL JOINTS & DUST OTH
DESCRIPTION:
SERVICE: INSPECT BATTERY ELECTROLYTE OTH
DESCRIPTION:
SERVICE: INSPECT BODY-PAINT/CORROSION OTH
DESCRIPTION:
SERVICE: INSPECT BRAKE FLUID OTH
DESCRIPTION:
SERVICE: INSPECT BRAKE PADS & DISKS OTH
DESCRIPTION:
SERVICE: INSPECT ENGINE COOLANT LEVEL OTH
DESCRIPTION:
SERVICE: INSPECT ENGINE DRIVE BELTS OTH
DESCRIPTION:
SERVICE: INSPECT EXHAUST SYSTEM OTH
DESCRIPTION:
SERVICE: INSPECT FOR FLUID LEAKS OTH
DESCRIPTION:
SERVICE: INSPECT INT. & EXT. LIGHTS OTH
DESCRIPTION:
SERVICE: INSPECT POWER STEERING FLUID OTH
DESCRIPTION:
SERVICE: INSPECT RADIATOR & HOSES OTH
DESCRIPTION:
SERVICE: INSPECT STEERING LINKAGE OTH
DESCRIPTION:
SERVICE: INSPECT TIRE PRESSURE OTH
DESCRIPTION:
SERVICE: INSPECT WINDSHIELD WASHER OTH
DESCRIPTION:
SERVICE: INSPECT WINDSHIELD WIPERS & OTH
DESCRIPTION:
SERVICE: OIL FILTER ASSEMBLY R&R
DESCRIPTION:
SERVICE: PARKING BRAKE ADJ
DESCRIPTION:
SERVICE: ROAD TEST OTH
DESCRIPTION:
SERVICE: TIRE ROTATION ROT
DESCRIPTION:
10699 MILES
DATE:
02/11/2003
REPAIR# 0134293
SERVICE:
DESCRIPTION: FRONT BRAKES AT 10 MM REAR BRAKES AT 9 MM REPLACE AT 2MM FRONT AND REAR TIRES MEASURE 11/32" COMPLETED SERVICE PER MENU
SERVICE: 10K MILE SERVICE (LX470)
DESCRIPTION:
SERVICE: CAR WASH OTH
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT AIR FILTER OTH
DESCRIPTION:
SERVICE: INSPECT AUTO TRANS FLUID OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT BOLTS & NUTS ON OTH
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT BRAKES OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
5561 MILES
DATE:
09/11/2002
REPAIR# 0127570
SERVICE:
DESCRIPTION: CLIENT STATES THE SPARE HAS NAIL,PLEASE PATCH SPARE TIRE. TIRE IS NOT REPAIRABLE,NAIL IN SIDEWALL. MOUNTED AND BALANCED 1 NEW TIRE AND PLACED AS SPARE.
SERVICE: 5000 MILE SERVICE (LX470) WARRANTY SERVICE
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: TIRE ROTATION ROT COMPLETED.
DESCRIPTION:
1786 MILES
DATE:
06/18/2002
REPAIR# 0123692
SERVICE: 1000 MILE SERVICE (LX470)
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT ENGINE OIL LEVEL OTH
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST OTH COMPLETED.
DESCRIPTION:
3 MILES
DATE:
05/07/2002
REPAIR# 0039558
REPORTED BY: Jim Falk Lexus of Beverly Hills
SERVICE: INSTALL PLATE FRAMES,INSERTS, SCREWS & CAPS
DESCRIPTION:
SERVICE: PRE DELIVERY SERVICE LS400/ES300/SC300/GS300
DESCRIPTION:
TERMS AND CONDITIONS
INFORMATION ACCURACY
Information presented on this website is summarized and standardized from repair orders completed at the time of service and submitted by Lexus dealers. When reviewing a vehicle?s service history, please note that all information is provided by the Lexus Dealer that conducted the service, and that dealer is solely responsible for the accuracy, completeness or authenticity of any information contained in this site. Lexus provides this site and all information and materials contained herein ?as is? without warranty of any kind. Any questions or concerns regarding this information should be addressed to the applicable Lexus dealer.
L/CERTIFIED OWNER INFORMATION
Dealer-reported service history records are linked to a vehicle's Vehicle Identification Number (VIN). All owner-reported service history records will be made available to the person who input the information on the site, but will not be shared with future owners of the vehicle.
OWNER-REPORTED INFORMATION AND PRIVACY TERMS
Lexus makes every effort to ensure the secure collection and transmission of sensitive user information using industry-accepted data collection and encryption methodologies. The information you provide is used by Lexus and its vendors and dealers to help improve the services we render. It is occasionally provided to Lexus dealers for their marketing use. Lexus will never sell your personally identifiable information to any other company. To learn more about our privacy policies and practices with respect to this website, please click here.
Carfax report:
Owner 1
Purchased: 2002
Low mileage! This owner drove less than the industry average of 15,000 miles per year.
Personal Vehicle
13,368 mi/yr
Date
Mileage
Source
Comments
04/25/2002
NICB
Vehicle manufactured
and shipped to original dealer
05/07/2002
Lexus of Beverly Hills, Inc.
Beverly Hills, CA
310-274-5200
beverlyhillslexus.co
m
4.2
29 Verified Reviews
Vehicle serviced
- Pre-delivery inspection completed
05/14/2002
15
California
Motor Vehicle Dept.
Danville, CA
Odometer reading reported
- First owner reported
- Titled or registered as personal vehicle
06/18/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Battery/charging system checked
- Undercoating/rustproofing inspected
- Tire condition and pressure checked
- Fluids checked
- Brake fluid checked
09/11/2002
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Oil and filter changed
- Fluids checked
- Brakes checked
- Air filter checked
- Steering/suspension checked
- Vehicle washed/detailed
- Tires rotated
02/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Brakes checked
- Fluids checked
- Tires rotated
05/29/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Recommended maintenance performed
- Exhaust system checked
- Wipers/washers checked
- Exterior lights checked
- Drive belts checked
- Differential fluid flushed/changed
- Air filter replaced
- Fluids checked
- Antifreeze/coolant checked
- Cooling system checked
- Tires rotated
- Parking brake adjusted
- Brakes checked
- Windshield washer checked
09/10/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 10,000 mile service performed
- Window(s) checked
12/11/2003
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 30,000 mile service performed
- Noise checked
- Radio/sound system checked
03/19/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
06/07/2004
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
10/07/2004
43,272
Monument Auto Masters
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Maintenance inspection completed
- Front brake pads replaced
- Rear brake pads replaced
- Transmission checked
- Fluids checked
- Brakes checked
- Window(s) checked
- Steering/suspension lubricated
01/05/2005
48,261
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
03/10/2005
52,556
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
04/28/2005
56,881
Concord, CA
925-798-8800
mthopeservice.com
5.0
5 Verified Reviews
Vehicle serviced
- Fluids checked
- Window(s) checked
07/08/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- CV boot(s) replaced
- Four wheel alignment performed
- Front strut(s) replaced
- Four tires replaced
10/29/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
12/02/2005
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- Tire repaired
01/30/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/02/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 75,000 mile service performed
07/12/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
11/18/2006
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
- 5,000 mile service performed
- Rear brakes serviced/adjusted
05/15/2007
California
Motor Vehicle Dept.
Danville, CA
Title issued or updated
- Registration updated when owner moved
the vehicle to a new location
07/19/2007
Lexus of Concord
Concord, CA
925-682-3033
lexusofconcord.com
4.5
84 Verified Reviews
Vehicle serviced
05/14/2008
111,151
California
Inspection Station
Passed emissions inspection
06/18/2010
137,247
California
Inspection Station
Danville, CA
04/20/2011
147,138
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
12/29/2011
151,423
Mike's Car Clinic
Dublin, CA
925-828-2100
mikescarclinic.net/
Vehicle serviced
06/04/2012
154,947
California
Inspection Station
Danville, CA
09/16/2013
170,936
D & D Automotive & Tire
San Ramon, CA
925-362-8755
Vehicle serviced
04/02/2014
176,861
California
Inspection Station
Concord, CA
05/10/2016
195,423
California
Inspection Station
Passed safety inspection
- Passed emissions inspection
05/02/2018
213,611
California
Inspection Station
09/09/2019
California
Motor Vehicle Dept.
Danville, CA
- Duplicate title issued
Odessa/Midland TX
The price is bit high for that truck. Did you see the frame? Check before buying as there can be corrosion. Is the transmisson a brand new unit or a remanufactured? Any remaining warranty on it?
Make sure the owner on the title is present at the time of the sale, else this is someone doing a business with a story. If you cannot meet the owner, I'd say it is suspicious and you may buy someones headache.
I bought my 00 LC with 222K miles for 4500.
Phoenix
Seems like a bargain to me and likely to be sold pretty quickly. But you need to see it in person or see a few dozen pictures to really know.
Northern California
looks like my twin, I would go look at it, single owner, bay area (most likely little to no rust) and serviced. The rear seats do look worn however, but timing belt done? where in Norcal are you?
JunkCrzr89
Competent Ignoramoose
Colorado
FWIW, I also paid $4500 for my 2000 LC with 214k miles in SoCal (only surface rust on the front bumper bar and nowhere else). However, based on appearance, mine was in rougher shape than this LX that you’re looking at appears to be in. Seller wanted $7k for mine, but after I showed them everything that needed replaced/fixed, they agreed to come down on the price. If I were you, I’d definitely checkout the front end (wheel bearings, ball joints, control arm bushings, steering rack, and shocks); they were all toast on mine when I bought it. This may help you talk the seller down closer to the $6-7k range...
Norcal
Alright so I ended up buying this rig, with some haggling, for $6700.
My impression from the location and the people was basically that this was some family's daily driver, and they took middling care of it. They did not have any of the records, which could be a major red flag, but the general impression of incompetence counteracted any fishiness to the story - they said they are in the process of moving and threw away most of their things. They had no clue about any of its functionality, including the AHC, yet I do not suspect that this was someone else's car, because the names/addresses on the title, ID and registration all match.
I took it for a PPI. Brakes ~50%. No rust, no leaks, no codes. Looks like it's never been offroad. No tow hitch. All four tires are the same although the rear ones are newer. I remembered the '7 gradations' check on the AHC and that was fine. All of the electronics in the car checked out, except I forgot to check the audio until I was already driving home - the sub is definitely either blown or the foam has deterioriated since it distorts/rumbles. Also the windshield has wind noise from the driver's side that I am guessing has to do with improperly fitted moldings, otherwise the car is very quiet.
On the exterior some dings and scrapes, which I don't care about, but also the rear bumper is loose on the driver's side and sags a bit. It's not seated properly. The interior is a little grody - taking it for detail tomorrow. Then I guess I need to 'baseline' it though I am not sure if everything that is suggested on this forum is necessary - I will be doing very little off-roading.
So far, as I understand it, baselining =
-all fluids and filters
-thermostat
-heater Ts
-lubing up the driveshaft
-repacking front wheel bearings
Water pump/timing belt done ~70k ago. Not sure about spark plugs.
JunkCrzr89
Colorado
Wheel bearings, ball joints, front control arm bushings, flush power steering and brakes, etc...
Norcal
Hehe I was just editing my list as I continue to read the baselining threads.
Will add the bushings/ball joints.
Michigan
Great find.. and an excellent price.
I bought a single owner 02 LC from Arizona last month for $9600.
177K miles zero rust with a great service record with toyota replacement parts.
timing belt replaced twice most recently last year. Dealer I purchased it from changed spark plugs, drive belt, 2 new tires, recharged A/C, new filter.
Almost everything else was in excellent condition.
My rear speaker was blown and the navigation dvd was busted. Both quick fixes from ebay.
Congrats
Norcal
Congrats
Is the subwoofer really a quick fix? Did you replace with OEM? I read a replacement thread and it seemed like you have to open up a lot of the interior in order to get at it.
And you just buy a replacement DVD from ebay, correct?
Southern California.
i was lazy and just pulled back the panel to squeeze it out and in with the rebuild kit from simply speakers.. tight fit but saved me lots of time.
Norcal
I count 5 bolts...a couple of them pretty low down from the top end of the panel. Did you skip all the steps with the skuff panel, seatbelt and seat anchors? Just go straight for the clips holding in the panel?
correct, just the bolts holding the top panel to allow me to bend it back and squeeze the sub out.
