Just use your regular god damned pipe wrenches, make sure you are pulling the two wrenches together and take the fawkin cap off. PB blaster won't do s*** but kill your flowers or stain your patio. Household gas pressure is like 1/2 psi. You won't make a spark, the gas will be very diffuse in the environment. Just man up and take it off.
If you position the wrenches correctly, you can use a prybar between the two wrench handles for even more leverage without worrying about twisting the nipple at all.
Dude, you really need to get a buddy nearby who you can trade beer for building trades advice or just sell your house and move into a rental before you kill yourself or your neighbors. These threads are really starting to show a trend of hazardous and ignorant behavior on your part.
Don't know about you, but I'm getting tried of seeing these dumba$$ posts by e666.
I don't know what is wrong with hiring a professional to do a job when it involves safety and/or code compliance? I guess some people are just too dumb and cheap that they're willing to risk the lives of their neighbors. They end up wasting other people's time and not listening to advice which they solicited.
I'm glad I don't live next to such dumba$$.
Not surprisingly, no talent of yours needed anywhere eh...?
I'd put you on my ignore list but it's entertaining to read the spouting off... if decidely repetitive unfortunately...
Hope you got some pipe dope as well. Tape works usually, but I've seen leaks with it, and never with liquid. If you do use tape, make sure it's suitable for NG- typical white tape is not.
Gas tape is usually on a yellow spool with black print around here, the tape itself is noticeably thicker and off-white. Pipe dope does not contribute to problems with loosening the joints later, in fact it helps keep threads clean and easy to loosen. The only downside that I'm aware of is cleanup- the stuff is a PITA and gets on everything. That said, I use it almost exclusively even thought the tape is much easier. I don't get a good feeling when using tape, and as mentioned before have seen it leak on water connections.
I'm not all that down on it. I too have had water leaks that were fixed with more tape. I have never had a leak with liquid stuff. So which am I going to trust with gas?
e9999: You sure you want the lower btu output from NG? I guess some do like a slow cooked steak...
Did you get the darn cap off yet?
I never use the white teflon tape, always the pink thicker stuff. Safe for gas as well. Never had it leak yet, and I've done loads of plumbing. I dont touch gas tho
