Well, having done a birf job last week on a fellow mudder's rig and seeing the wear on a truck with ~180K with no recorded birf job, I went in to my rig this evening.
A couple of contextual notes:
Been having some vibration/steering issues as of late and have crossed off drive line issues as I have PM'ed them to death (full drive shaft rebuilds, etc.) Driving back from NJ yesterday and pulled over at a rest stop and just gandered under the rig. The bottom 4 knuckle studs/nuts attached to the DS axle had all basically back themselves out!!
Tightened them and ride was better. Got me thinking.
I did a full birfield job at 127K (currently at 160K). I figured it was at least time to repack bearings if anything.
Passenger side looke pretty good...except for the rust around the upper and lower trunion bearings and rust developing underneath the knuckle housing.
Driver side was a mess. The inner wheel bearing had seized itself to the spindle due to rust and corrosion. The upper and lower trunions were covered in rust and the bearings were barely spinning freely...
Amazingly, the M1 wheel bearing grease I had used on the wheel bearings and the trunions was still red!! Very little deterioration and still had strong coating qualities.
The DS spindle was scored a bit, but with some wire wheeling, some die grinding, and some scotch briting, I was able to get it back nice and smooth.
The birfields after disassemble looked real nice. Some slight scoring, but again, easily taken care of with some die grinding and some scotch briting.
I attribute my deterioration to two water related events:
1. DS axle being submerged in muck, mud and water for about 30 minutes in October.
2. Both PS/DS being submerged for periods of time at the Badlands in December.
Water is thy enemy!!!! I can see why the importance of checking bearings etc., after driving rig through considerable amounts of water/mud.
In any event, things are soaking as we speak for a put together tomorrow eve. I think Toyota intervals for this work (30K--bearing repack; 60K birfield job) should be changed for those of us who frequent water or mud.
Just in time as Landwagon and I travel to Badlands again on Friday for some more water!!
This time, I'll be checking out stuff next week.
Anyway, just another MUD data point for all the anal PM folks out there.
Best regards.
-onur
Akron, OH
PS: This front axle stuff gets easier and easier as time goes by....I had both sides taken apart in less than 1.5 hours....a new record for me.
Best regards.
-onur
Akron, OH
