hello,
stupid question of the day. Do you adjust the timing first or the idle first. How can you adjust one without the other being correct. I am having the chicken before the egg conversation in my head and I cannot figure it out.
for reference, no emissions are on this motor. I started capping off all vac ports and the 2f now idles high. before they were plugged it ran low to off. you had to pull the choke at stop lights and keep you foot on the peddle. I started the cruiser and it's running around 2000 rpm, turned the idle screw all the way out and it only dropped to 1500. the a/c idle screw is all the way out also. SO I am guessing that the timing is set real high due to the mess of a state that the 2f is in. If I tone down the timing, will the motor just shut off if the idle is not correct? how do I set the idle if it will not go below 1500 rpms?
do I:
a. run the idle screw all the way out
b. adjust the timing
c. adjust the idle.
do I:
c. adjust the idle.
