Just curious, will you also add a new display for the new camera, or just connect back to the stock screen?its the stock camera (17 years old now) and I'm replacing it with an aftermarket camera
NO. just wire into factory wiring.Just curious, will you also add a new display for the new camera, or just connect back to the stock screen?
I haven’t checked but I’m going to say yes and for $30.00 order a pair and post back in this thread. TRS will take them back if they don’t fit.My year model LX470 has the back up light location in the tail lamp (not separate near the license plate).
Would the GTR Carbide 2 bulbs still fit and function in that application. Would love to have more light back there.
I was just on the TRS site and put in the earlier model year and the GTR backup bulb did come up as a fit but their site also indicated the $100.00 bulb would fit my 2006 and it didn’t. If you want to wait a week I just ordered 30 pairs to list on my site ... I’ll test fit them in a earlier model and report back. Digging around on the WEB which may or not be correct, the bulb size for a 2002 LX reverse is coming up as 921 which matches the bulbs I ordered but I’ll verify that shortly unless someone on MUD knows the answerMy year model LX470 has the back up light location in the tail lamp (not separate near the license plate).
Thanks for identifying the correct bulb size.. I also just spoke to TRS and they do make a 7440/7443 GTR Carbide2.0 but it’s twice the cost as the 921. It has two extra LED chips but produces the same 1200 lumens for $69.00. I know $69.00 is a big number for bulbs but the light output is sick. I ordered two to test fit.... if you plan on ordering before I test fit make sure you select White in the drop down.Will wait to see what you find out. I just replaced all of my tail lamp bulbs a couple of days ago with (7443) and I don't want to go back in there without knowing the bulb will work. So will wait to see what you find out, then order from you IF they do. Thanks
I should have both by Monday and compare....they are both wedge basedI'll wait to see what you find. It's a 'wedge' bulb base and it might well be that it will fit my bulb receptacle either (as is) or with slight trimming.
If that is the case then I'll order a set and a spare set from you.
