add-a-leaf+longer shackles= need for longer shocks?
Discussion in '40- & 55-Series Tech' started by B6i6K6e6R6b6O6y, Jun 30, 2005.
  1. B6i6K6e6R6b6O6y
    B6i6K6e6R6b6O6y
    346
    Jan 17, 2005
    wenatchee
    I just got 2" longer shackles and a set of add-a-leafs and I was thinking that it might be a good idea to get longer shocks? since I'll be getting new ones soon anyhow. any input would be great. thanks
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    Get 'em.
    Good luck!
    -Steve
  3. Bodean
    Bodean Hot Damn SILVER Star
    11,428
    Media:
    18
    Albums:
    1
    3,183
    Dec 20, 2004
    Brandon, MS
    Maybe extra padding for the seats with the add-a leaf! I had them ONCE and couldn't get new "lift" springs fast enough!
    Later,
  4. woody
    woody unhelpful spotter Staff Member Admin
    10,962
    Media:
    317
    Albums:
    8
    2,950
    Jan 15, 2002
    Toquerville UT
    you'll probably end up with 2" total lift....to make it easy, pick up shocks for a 2-1/2" lift....I'd think that'd work....
  5. B6i6K6e6R6b6O6y
    B6i6K6e6R6b6O6y
    346
    Jan 17, 2005
    wenatchee
    what size of tire do you guys think I could clear whith this setup? I was thinking that if I cut the rear fenders out a little that I could clear some 35".
  6. Bodean
    11,428
    Media:
    18
    Albums:
    1
    3,183
    Dec 20, 2004
    Brandon, MS
    Maybe some 33" at the most. I ran 33x10.5 swampers with 2" springs and shackle lift without cutting the rear. No rubbing. 35's will rub.
    Later,
  7. t-o
    t-o
    206
    25
    Apr 28, 2004
    With this same add-a-leaf and 2"-over-stock shackle setup on my '75, my old 32x11.5" BFG MTs rubbed the rear inside fenders when stuffed. so 35s would definitely rub.
    At some point the 25-year-old shocks wore out on the rear; the replacement Rancho 5000s I bought were size RS5116. We found this size by trial and error, the 2.5 inch lift shock specified in the parts book was way too short. The length works OK, doesn't limit anything...the ride is moderately better than my old riding lawnmower.
    Tim
