Access to fogs?
Conroe, Tx
I want to get access to the fogs on my ‘18 to install the Tundra Baja Design fog kit. Im not finding any install post on it, or any guides for geting access to the area. Im assuming the whole bumper needs to be removed? Will I be able to get to it through the wheel well only?
I think ARB as a removal vid in prep for their bumper install, anything else?
thanks
Scroll down.
You can access them by removing the splash guards.
But Fwiw popping the bumper off is quite easy and would give you lots of room to work. You need to remove the front skid plate and splash guards and the clips across the radiator support. Once you do that you can gently pull the bumper skin loose along the wheel opening. You’ll need to disconnect parking sensors etc but it’s very easy.
