Access to clutch and flywheel, 69 FJ40: Easier way?
Discussion in '40- & 55-Series Tech' started by melvinjo, May 17, 2018.
  1. melvinjo
    melvinjo
    234
    41
    Aug 28, 2010
    I need to change out my clutch plate on my 69, FJ40.
    What's the easiest way to access:
    1. Remove transmission and high low gear box and remove clutch pack with egine still in vehicle?
    OR
    2. Remove motor after removing the four, bell housing to tranny bolts and changing out the clucth pack with the engine out?
  2. pjohnson
    pjohnson SILVER Star
    1,292
    Media:
    108
    Albums:
    11
    352
    Jan 15, 2003
    GarlicLand, Kalifornia
    Many more items to disconnect with option 2.
    Rent a tranny jack and bribe a couple friends to help.
    rrv333 likes this.
  3. Tezmac
    Tezmac
    168
    Media:
    12
    Albums:
    1
    56
    Sep 17, 2005
    Where Bugs Shoulda Made a Left...
    I did my early '70 with the engine left in-place. It took me more time to remove the interior to get the transmission hump off than it did to drop the transmission/xfer case as one and and get the clutch replaced.
    If your oil pan or rear main seal leak, your rear motor mounts need replacing, or your flywheel needs to be machined, now's the time to do that as well, since you'll already have the majority of the work done needed to address those items.
    mrboatman and lc69hunter like this.
  4. Geezer Cruzzer
    Geezer Cruzzer
    227
    Media:
    65
    Albums:
    7
    314
    May 13, 2017
    Buena Vista, Colorado
    Don't forget the rear u-joints!
    lc69hunter likes this.
  5. lc69hunter
    lc69hunter SILVER Star
    1,392
    195
    Oct 19, 2006
    Tucson
    If you are also rebuilding the engine, pull the both out the front. If not, take out the seats, and probably the gas tank, remove the hump and pull it out that way, either from the top with a jury rigged hoist, or transmission jack from below. I have done it alone, but cursed a lot. It should be a two man job.
  6. Tancruiser
    Tancruiser
    1,591
    Media:
    2
    Albums:
    1
    1,540
    Sep 16, 2006
    Steamboat Springs Colorado
    Is this a floor shift or colum shift? I’ve changed a clutch without removing any interior parts on s colum shift.
  7. Martyt
    Martyt SILVER Star
    716
    748
    Feb 13, 2018
    San Diego
    Option 1 is the route to take and, while in the neighborhood, replace ancillary clutch parts.
