Anyone know a recommended clearance between the factory tube crossmember and e-brake drum? This is on a Feb 1970 FJ40 with 2F, SM465, plate adapter, and factory 3 speed tcase. With the extra length of the SM465 and plate adaptor, the rear of the tcase is 115mm further rearward that the original setup was and now clearance between the tube crossmember right behind the tcase and the e-brake drum is an issue. I "massaged" the crossmember with a torch and hammer to gain some clearance. Figure since the crossmember just keeps spacing between the frame rails a small amount of massaging won't hurt anything. I'm at about 1/8" right now. How much does that clearance change during wheeling? Does the frame and crossmember flex enough to eat up clearance? I don't want to go with an aftermarket crossmember.
Thanks all,
Stephan
Thanks all,
Stephan
