This is on a 93 1fz.
When acceleratingy vehicle does the following.
In the video I am applying constant pressure on the gas pedal, I'm not lifting my foot up or anything.
It only does this if you give it medium to wide open acceleration. If you just go easy on the gas it won't do it and will accerlate all the way to highway speeds no issue.
I recently replaced the spark plugs with plugs from toyota. All gaps were checked at .032 and all installed to 14lbs.
I am assuming this is a misfire on a cylinder or a plug not working correctly? Just want to double-check with you guys if there is anything else I should check before I pull all the plugs again or put the old ones back in.
