Acceleration from idle – 78 FJ40 stock carburetor.
Redwood City, CA
I’m almost done with some interior stuff (4th gear switch on transmission fixed, interior cleanup with POR15, etc.) and should soon have my 78 moving again. First thing I want to do is attack my carburetor issues and get it rebuilt if I can’t get everything close to right.
I’ve done a bunch of stuff to the engine (cleaned a bunch of garbage out of the carburetor at the main gas inlet) and now the truck always starts easily, and runs fairly well when warm. Even when the truck is cold, with no choke, I can push the gas pedal 2 or 3 times, turn the key and it fires up and will sit and run at a low idle (choke pushed in). But when I give it gas, it will stutter and die, so I usually end up pulling the choke anyway to get it going. The warmer it gets, the less affected but it’s not a smooth initial transition to higher RPM. I’m going to step through the whole tune-up process again once I get it running but hoped someone might have some insight. BTY, valve adjustment, timing, new plugs, new gas filter, etc. etc. have been done. Thanks for any feedback.
It is normal to need the choke for it to start and run when cold, even in the bay area. It is not normal that it would run well w/o the choke when cold, so maybe someone has fooled with it in an attempt to make it run, like turn up the idle speed to compensate for a lack of idle fuel.
There are two fuel circuits that help to smooth the transition from idle to higher speed: the accelerator pump and the transition slot that sits just above the throttle plate in the primary bore. You can see the pump squirt fuel into the primary when you open the throttle, so it is easy to check. The transition slot gets its fuel from the idle circuit, so make sure that the idle fuel cut off solenoid is working. You can also check if the idle circuit is getting fuel by turning in the idle mixture screw (next to the valve cover) all the way (gently) until it stops. If it runs with the idle fuel cut off, it is probably not getting idle fuel and is running off of fuel from the main nozzle.
Thanks Fast Eddy/Pin_Head.
I picked up an Actron Vacuum gage. Is the brake booster the "accepted standard" location to connect a vacuum gage?
That should do it, but that hose is pretty big to fit onto the gauge, and you want to be very careful not to break that plastic. Maybe pull the other end and make up a hose combo to deal with the size difference.
Coming down for the Meet & Greet tomorrow in San Jose? http://www.mta4x4.com/html/meet_n__greet.html
We can be little olive 1978 twins. :)
Coming down for the Meet & Greet tomorrow in San Jose? Meet n' Greet
That would be cool but I would need to sit on an orange crate and hold a gas can on my lap to get there (check out the photo). Any hoo – I need some serious cosmetic surgery upgrades before I can park my old rust bucket next to your clean Olive in public. :D
Hope to take you up on it in future.
No. At least not in my experience. That hose too big. I think most vacuum gauges like 1/8th" tubing. You should have plenty of the small vac lines coming off the intake manifold that you can "T" into...
I don't have quite so many vac lines (2), so I used one of the empty threaded ports on the topside of the intake manifold.
