This is my very first time messing with the AC so I need some second opinions. AC is not cooling like it should as the temp goes up. When connect up the gauges my static readings are 50 on the low side and 50 on the high side. However, when I run the AC low drops to ZERO and the high side goes up to 100. Which are both low. My assumption is that I have a freon leak somewhere and I suspect its the in the line that goes to the rear AC. I have added dye and have been unable to find any leak so far. However, from what I have read on MUD the rear AC line is covered in several parts so I need to inspect further to confirm my initial assumption. Do those readings indicate my initial thought or am I way off? Thanks
