Now that it's gotten hot out my ac has decide to stop working. It a hj61 24v system. From researching a bit I'm thinking it the clutch coil. The fuse blows immediately when you hit the switch. Unplugged the compressor and the fuse doesn't blow. Most people that have had this problem found it was a bad clutch coil but mine appears fine. I couldn't find anything about checking resistance on the coil in the fsm. The wiring appears good could there be anything else shorting it out?
Hopefully I can find a clutch and just replace that. The compressor is in good shape.
