What is the bolt just below the sight glass on the ac dryer? Is it supposed to have a pin hole in the center? If so why do I have r-134a leaking out of the pin hole?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Can anyone else verify that they do or dont have a pin hole in the center of this bolt?
It's a fuse plug. Basically it a lead plug that melts if the refrigerant temp gets to high. Once it's open, it will eventually release all the refrigerant. The only option is to replace it. The Denso drier has a 8mm x 1.25 pitch fuse plug. Aftermarket driers may use something more common, but it will probably be easier to just replace the drier than to find that fuse plug.
