ABS / Lockers (1 Viewer)
I'm new to the board so please pardon any redundancy in this question.
I have a 95 LC and the ABS is out because of a bad front wheel sensor. Will this interfere with the lockers engaging?
I have the front and rear lockers.
Thanks
It should not stop the lockers from engageing as the centre diff lock turns off the abs when it is engaged. DO NOT engage the lockers on pavement. Go to a gravel road or parking lot. Shift into low to engage the centre diff lock. Engage the fr & rr diff locks and drive around a bit. If the front engages the steering will get very stiff and you know everything is working as the front will only engage once the centre and then the rear engage.
Cheers
Sean
>> Will this interfere with the lockers engaging? <<
No.
-B-
