It should not stop the lockers from engageing as the centre diff lock turns off the abs when it is engaged. DO NOT engage the lockers on pavement. Go to a gravel road or parking lot. Shift into low to engage the centre diff lock. Engage the fr & rr diff locks and drive around a bit. If the front engages the steering will get very stiff and you know everything is working as the front will only engage once the centre and then the rear engage.
Cheers
Sean
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
