ABS kicking on after shifting into gear.
Mark97LC
Enterprise, al
So this just started happening. When I crank the truck and shift into R or D and start to move I can hear the ABS (or what sounds like the ABS) pump kicking on and cycling a couple times. 25% of the time the ABS light will then kick on. The other times its fine. It only does it on initial start up and its every time.
I have not done anything to the braking system since July. Installed new Rotors and pads when I did the Birfs around mid July. No issues until now (2000 miles+/-).
Brake fluid level is fine. I have tried to find a similar situation in the search but nothing came up that matched. Any direction to eliminate this issue would be great.
