I had brake fluid above the MAX line so followed the instructions on the MC to bring it to level but for some reason the pedal would not drop to the floor. So I stopped and drove after that with no issues but in the morning my brake felt soft on 1st pedal.
I kinda panicked due to the price associated with the repair. Any ways I got fluid and followed the FAQ to bleed the brakes.
The pedal went to the floor in 20 this time and I corrected the fluid level and also bled the brakes but now the pump will not turn on when I put the key in ignition. It will turn on if I press the pedal couple of times. If I keep on pressing the pedal couple of more times the ABS light will start beeping and will go off once the pump is on and brings the pressure back.
The Pedal also went to the floor when I pressed hard on the brakes while on a test drive.
At not time did I let the reservoir go below MIN level. Is there air in the MC or the booster should I take it to Toyota/Lexus for bleed?
Thank You
Hopefully it is nothing big.
Thank You
