AA rear crossmember with bracketts and mounts
Status
Not open for further replies.
Is this to replace the "torque tube" part for a 40?
My 40 is in desperate need of a crossmember. If this will work with the stock tranny/tcase Im down. Parcel Post is cheaper for me. If thats cool, let me know. Thanks!
Will it work with the stock drivetrain and take the place of that crossmember that I am missing? If so, I will take it.
i assume the cross memeber you're missing is the round steel tube with a bend off to one side to clear the driveshaft. it mounts in the frame right behind the transfer case. that crossmember is designed to strengthen the frame, but does not support the t-case or transmission.
the one i'm selling is designed to support the trans and t-case from the rear, but does not strengthen the frame in any way.
i'd say you find somebody with a bad frame and cut that cross member out and then weld it in yours. or you can get a fab shop to bend you up a piece of tube and weld it in. just make sure it's bent to proper specs so it clears the drive shaft.
Yeah, unfortunately you're right. I was hoping it would have worked but it wont.
Status
