A343F
so which transmission do i have if i have a 1997 LC? 442 or 343?
Some 1995 models don't have OBDII, so those don't run the same computer or wiring harnesses as the '96+. Essentially, some 95's are built the same as 94 and older, and some 95's are built with the newer specs. You can't just drop in a computer-controlled transmission into a vehicle that doesn't have the computer hardware, harnesses, etc. to talk to it, or vice-versa.1995-1997 From Slee ..
- Automatic transmission changes to the A343F. Some 95’s were produced with the A442F. The transmission type is printed on the label on the driver door.
It appears that the A343F & A442F are bolt up replaceable .. Don't think the bolt patterns would change .. Mounting points are the bigger question ..
Here's a shot in the dark to revive an old thread. I've got a 95 HDFT engine in my 94 (U.S. spec cruiser) and all that I know is that the transmission and transfer case came out of the Japanese cruiser (it was an imported half-cut). I don't have the VIN number on the donor rig and am having trouble identifying which transmission I have (it has a leak in the rear of the transmission and I need to order some parts).
Long story, short the conversion was done by my stepdad over a decade ago and he has since passed away, and a lot of the conversion details were lost. I'm still digging through receipts to track down modifications that I didn't help with. I do know that a Nomad heavy-duty valve body was installed during the conversion. From the hours of google searches, I think it is an A442F but thought I would finally ask the question here. Any help would be greatly appreciated. (Serial Number pic on transmission for attention).
Electronic or hydraulic?The only automatic transmission ever paired with the 1HD-FT was the A442f. So if they came together, that’s your answer.
95 would be electronic. Fully hydraulic was 91-92 at least for the Japanese domestic market.Electronic or hydraulic?
Thank you!The only automatic transmission ever paired with the 1HD-FT was the A442f. So if they came together, that’s your answer.
