A thermostat is a thermostat is a?
Walnut, Ca
A search revealed a whole lot of other stuff !!!
In my case all cooling system was recently renewed with all new hoses water pump radiator and 8 blade fan.
Last night I went for a little cruize weather was about 60F, my idiot temp light was really high, I turned around and went home. I popped the hood and the hoses and radiator was really really hot.
So today I pulled the thermostat housing and Im wondering if my thermostat is working or not. I further discovered i probably have 90/10 antifreeze far too green so I will drain and try 60/40.
Is this after market 180f stat ok for my rig, or should I have picked up an oem stat.
I also noticed the upper rubber gasket does not fit properly on the stat but does fit perfectly on inner top housing, is this a proper fitting, could this be contributing to what i believe is a hotter than normal running system.
Im going to pick up a mechanical temp gauge for a piece of mind and avoid a cracked head.
I noticed some guys place food/cooking thermometers into the fins of their radiators, is this effective and what should temps run at while on highway.
Im going to try running without a stat to see what happens in the mean time.
Walnut, Ca
Will any thermostat that fits work, this is an aftermarket one along with rubber gasket from kragens .
Gun Runner 5
First and Final Warning!!
Thomasville, GA
While I have no opinion on what thermostat to install I can suggest replacing your antifreeze with "Evans Coolant" which is not water based and offers a much larger range of protection.
You can find additional information on this product on the Forum.
.............1978HJ45
myquestoyota
Western WA
thermostat check
Did you do the pan on the stove hot water does the thermostat open check?
Redding CA
I am of the school of if you go through all the trouble to remove the thermostat don't test just replace it with a good quality t-stat.
myquestoyota
Western WA
doesn't hurt to check
I just mentioned it as a way to troubleshoot, I thought it was a new thermostat, may or may not be the problem.
I prefer to test parts as opposed to changing them until I find what's wrong. Save my $ for the problems.
Walnut, Ca
The thermostat was purchased new, while this was removed it was tested and worked accordingly. Today I ordered a factory oem rubber and paper gasket. The thermostat removal and installation is as easy as pumping gas, so I dont mind it however the siliconing part I do mind a bit.
Does anyone have a good aftermarket stat part #. The dealer wants $50.00 . Also ive seen rock auto has 2 or 3 different styles, do they all perform equally ???
Ill try that evans coolant you suggested hj45 ! thanks
Im going to try a few things today.....run an aftermarket temp gauge, clean the sending unit and attachement adjusting the coolant/antifreeze to different concentration and burbing the system.
