A/T Transmission FJZ80 95 yr -442F Type
Discussion in '80-Series Tech' started by kfarea, Aug 15, 2005.
  1. kfarea
    kfarea
    48
    Mar 29, 2005
    Here are my observations:
    Each morning (cold start) ,after waiting for RPM lowers to 0.6k, when shifting P or N to R.
    1st: I notice delay & high shift shock when the position light "R" on the dashboard shows immediately.
    2nd: Sometimes no shifting when the position light "R" on the dashboard won't show for a few minutes.
    Moreover, when driving, I noticed delay shifting 1 to 2 and then 2 to 3. All these cases only in cold start driving. Then after driving for 5 miles no N or P to R, 1-2 delay shifting appears while still noticed 2-3 low delay shifting.
    I changed ATM oil and filter, checked shift switch by positioning the car gear on R , D and switch on the engine. no starting.
    What could be the solution:confused:
  2. kfarea
    kfarea
    48
    Mar 29, 2005
    perhaps I was writing Chinese
    :rolleyes:
  3. kfarea
    kfarea
    48
    Mar 29, 2005
    I share You The Same Problem. I hope you had a solution
    I share you the same problem
